Greetings-New Owner of a Case 210
   / Greetings-New Owner of a Case 210 #1
deepstage
case 210
Hi All
I'm a new member due to the fact that I have just purchased a 1979 Case 210 compact tractor. This machine is replacing a Cub Cadet that I have had for the last 14 years. The Cub met an untimely demise recently and I was desperate to find a replacement being that the leaves are rapidly covering my lawn. I found a few tractors to check out on Craigs List, including this nice looking, but older, Case. Buying this older but much more stout tractor was an easy decision.
The tractor came with a snow plow blade but it looks like I may be missing some pieces to mount it. If someone out there may have this set up I would appreciate it if you could post or email a picture of the bracket/pieces which mount the blade to the machine. Thanks!
   / Greetings-New Owner of a Case 210 #3
Welcome to TBN. :)
Kick back enjoy and do share w/us.
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
UNUSED JMR 40" HYD ROCK GRAPPLE (A54757)
UNUSED JMR 40" HYD...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A52377)
2017 Mack GU713...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
