Grubbing Tongs
   / Grubbing Tongs #1
Anonymous Poster
Epic Contributor
My appreciation to all who posted info on the Tongs. I finally figured out they are the answer to one of my problems. We can all use something to save time and make those jobs easier!!
Thanks Again
   / Grubbing Tongs #2
Greg H - Have you purchased them yet? They are extremely useful - had I known how much so, I'd have gotten them a lot sooner.
One enhancement I made to mine that you might find useful (you know I can't leave anything alone): I took a shackle, and put a pulley on the shaft. My friend with the metal lathe made a couple spacers to keep it centered, and welded a plate across the throat to keep the cable on the tongs in the groove in the pulley. With it, the cable has a nice round surface to pull against and the chain hook can pull against the shackle. I think the cable will last longer that way and it's a little easier handle the chain hookup, too.
Mark
   / Grubbing Tongs
Mark I am ordering the Tongs today. Sounds as if your improvements to it are worth while. After i have some playtime with them I may try the same thing. Thanks for the info. Do you own anything that you havent modified??
   / Grubbing Tongs #4
GregH - Have you gotten the tongs yet? Just curious what you think of them.
BTW, I do have a '96 VW Passat diesel that's pretty much unmodified, except for a CB and scanner. /w3tcompact/icons/smile.gif
Mark
   / Grubbing Tongs
Mark they haven't arrived yet. I am looking forward to UPS every day hoping they come in. Will advise as the situation develops.
Greg
   / Grubbing Tongs #6
8/2
I have a trick with tongs that I would like to run past the safety minded group here. It is for overcoming the tendency they have for jumping off of logs you are trying to drag lengthwise before a bite can be achieved. Got the picture?
Saturday I knocked down a 9-12 inch stinkweed and tried to drag it back into the parking lot. It took a number of attempts to get the tongs to attach before the upward or even the horizontal pull jerked them off. It takes a lot of time to go back n forth (and I have a cab) /w3tcompact/icons/frown.gif. Cords would seem to be a solution /w3tcompact/icons/smile.gif.
How about using a couple of bunge cords or similar to wrap around the log/tree to hold the tongs on until you can pull hard enough to dig the points in?
Jim
   / Grubbing Tongs #7
Jim - For stuff like that, I use a choker chain. I've had the same problem you had with skidding tongs.
By the way, the grubbing tongs are totally different from skidding tongs.
Mark
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
