GST 4330 - Noise in rear end
   / GST 4330 - Noise in rear end #1
Mike_VT
Vermont
Kubota L4740 HSTC
Just took delivery of a new gst 4330, only 1 hr. While driving I thought the rear end gears sounded loud or whinny. Louder than the engine. This was especially true when shifting into high gears and when letting off the gas. There did not seem to be the whinning in low gears.
Also there was one occasion when I shifted and the transmission read out gear #7 on the panel , but was actually in neutral as the tractor would not move.
Is the noise level normal? and has anyone ever experienced the neutral issue? Any help would be appreciated.
   / GST 4330 - Noise in rear end #3
I don't think you've got anything to worry about, Mike. Sounds like it's probably just spur gear noise.
The final drive in Kubota CUTS is spur gear. I believe this is true even for the Grand L, although the specs are vague on that point. The big disadvantage of the spur gear design is noise. Other than that, they're simple, rugged, inexpensive and light weight.
U.S. built tractors traditionally had a planetary final drive. Quieter but much more expensive to produce and heavier. If you're used to the old Farmalls and Fords, the first exposure to the noise of spur gear drive can be a shock. After awhile you get used to it.
My L4300 behaves exactly as you described. In the lower 4 gears (I call them the working gears) it's pretty quiet. In the top 4 (travelling gears) it's loud. I guess it could wear on you if a lot of road travel was required.
Keep an eye on your transmission fluid and mention the noise to your Kubota salesman when you bring up the bogus gear indication. I think he'll confirm that "they're all like that" /forums/images/graemlins/crazy.gif
FWIW
Bob
   / GST 4330 - Noise in rear end #4
FWIW
Bob
   / GST 4330 - Noise in rear end #5
I'm not sure about the noise... but I had a similar experience with a GST I testdrove going into neutral when trying to shift gears. It was much worse than yours, this tractor did it every 3rd shift. As the tractor sat there in "neutral" there was a rhythmic jerking like something was trying to engage. That transmission also shifted very slow, with large pauses between gears and was pretty jerky when they engaged.
Two different people at the dealer gave different excuses (which I take to mean they had no clue why it was doing it). One guy said "They're all like that for the first 2-3 hours of operation. Once the hydraulic valves break in they're fine." The other guy said they had changed something on the tractor (I think he said tires... it's hard to make out exactly what someone is saying when they're chewing on a big plug of tobacco) and hadn't reprogrammed the transmission.
   / GST 4330 - Noise in rear end #6
Thanks...I am hoping that the dealer will be able to shed some more light. I will keep you posted.
Year: 2013 Make: International Model: WorkStar 7400 Vehicle Type: Truck Mileage: Plate: Body Type: (A55852)
Year: 2013 Make...
JOHN DEERE 331G SKID STEER (A52706)
JOHN DEERE 331G...
1999 CATERPILLAR 302.5 EXCAVATOR (A52706)
1999 CATERPILLAR...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
