GT-14 PTO belt and other kinds of things
   / GT-14 PTO belt and other kinds of things #1
Oatzman9000
Yanmar GT14
Hi. I have a GT14 does anyone have a good source for the PTO drive belt? I've tried tractor supply belts and they get twisted and burn up. seems like it needs a 1/2" wide but by deeeep V.. by a long measurement which I've forgotten
BM480 deck works fine with the TS belts but if anyone has more experience and knows what it really likes, let me know.
I'm using on a hill and most keep to the flat areas, but it does like to spin out and get stuck on inclines, it has the normal turf tires. has anyone experimented with tractor tread tires on these?
I also ordered off ebay a rear pto kit, I'm going to put the link all broken up in a post below this because as a newcomer i cant post links and it will tell me that after deleteing what i just wrote.. but is this all I need or is this kit missing anything like an inner driveshaft or something?
sorry I'm not home by my manual or tractor.. im sitting in a dirt lot a good 500 miles away, so I just figured I'd ask if anyone here knows these kinds of things i might get ordered before getting home. Thanks for any help'
I can has more post
Yes ya cannnnn
   / GT-14 PTO belt and other kinds of things #5
The GT14 has a lot of torque and most belts don't hold up very well.
We only recommend and sell the Aramid fiber (Kevlar) reinforced belts. The BM480 calls for a 5/8" wide belt
Everything you need to mount and use the rear PTO comes in the kit.
The gearbox has a splined shaft out the front onto which you place the splined coupler, then slide it onto the splined shaft on the rear of the transaxle.
You need to remove the rubber cover which is covering the end of that shaft.
Then follow the instructions which are included in the kit
Awesome, thanks'
I take It I bought the kit from you then. Would you make a listing both the gt14 front pto belt and bm480sb-e decck belt? or do you have a business website where I can buy these?
I must have bought 8 belts last year trying to guestimate what I need.
   / GT-14 PTO belt and other kinds of things #7
Awesome, thanks'
I will send you a private message with details on how to order.
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
County Line 5' Poly Feed Trough (A50515)
County Line 5'...
