Handgun for arthritis
   / Handgun for arthritis #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
My shootin hand, the right hand has arthritis pretty bad in some fingers. Trigger finger can't pull the trigger on several semi autos I have tried. The pull is too heavy and the travel is too long. Making it worse, I have long fingers and too many guns seem to be sized for smaller hands. I can rack the slide, but my thumb can't release it--can't move close enough to the tang to get a good push on it.
Got out my old Ruger .357 Blackhawk when there was a cougar on the property and that's when I found out I have problems. Excellent trigger pull, short travel and light pull. Best trigger of all the ones I have tried. But I can't cock the thing one handed--it's that thumb again.
Sun shop sales people say they are seeing a lot of people with arthritis as the boomers age.
So what's a good handgun for folks like me?
   / Handgun for arthritis #2
I would say something with less recoil.Maybe 22 mag.cal.Smith & wesson air weight.Have the trigger lightened up by a good gunsmith.
   / Handgun for arthritis #3
If you hands are that screwed up, switching to a pump rifle might be a better choice. You can mount a scope and see what you are shooting at as your eyes fail too.
   / Handgun for arthritis #4
Go with a 1911 model in .45ACP or 9mm. Rack it back to load and with a nice short 3/16" travel, 4 to 5 lb. trigger pull.
   / Handgun for arthritis #5
Since the Blackhawk is a single action revolver, the trigger would tend to be very light as compared to most double action revolvers. For that reason and the fact that you say operating a slide is not an issue, I would look for a single action semi auto with a nice light trigger pull.
If your arthritis is primarily in your right hand you can operate your slide release with your left hand. That's what I do and I don't have the arthritis problem (yet anyway). It allows you to keep a proper grip on your weapon and not have to shift your right hand around to operate the release. I always fire with a 2 hand grip anyway, so it's a natural movement to use my left thumb to operate the release then just fold it over your right thumb before firing. Takes a lot longer to say it than it does to do it.
   / Handgun for arthritis #6
Springfield XD,or any of the striker fired auto loaders.Everybody has copied Springfield and offer a striker fired auto's.
   / Handgun for arthritis #8
The only answer for shooting one - handed is a light triggered Glock,,I like the Model 17.
I hit things with the 17 that should normally require a rifle,, or at least a shotgun.
My only other nice to shoot gun is a S&W Model 629 with mild reloads,,
Actually a gun-smithed Model 629 can be fired double action with a remarkably low force.
   / Handgun for arthritis #9
I would think you might start training yourself to better utilize your left hand. Use your left thumb to cock the hammer on your Blackhawk. I doubt you'll find a better single action trigger on any semi-auto anyway (says the revolver guy :D).
Short of that, as Larry mentioned above, you may want to consider a rifle.
   / Handgun for arthritis #10
Pilot, if you really like the single action. I'm sure you could get it modified. Many years ago I was recovering from a spinal court injury and my hands were quite weak. I used a single action Ruger and pulled the hammer back with the blade of my left hand. A good smith could install a "quick draw" hammer extension which would help.
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
