Harbor Freight Solar Panel Battery Charger
   / Harbor Freight Solar Panel Battery Charger #1
FarmTracRay
Wabash valley, Indiana
Farmtrac 300dtc
I bought one of the 12 buck solar battery chargers from harbor freight a while back. Got ready to use it and thought I would check with volt meter first to make sure it put out. 24 volts!!!!! This may be a stupid question for you super smart guys, (common sense tells me it would) but will it hurt a 12 volt battery at 1 1/2 amp. I've learned so much here just observing. Thanks. Ray
   / Harbor Freight Solar Panel Battery Charger #2
Not to worry - your voltmeter has a high impedance input, you are measuring essentially open circuit. As soon as you place a load (connect it to the battery) the voltage will come down.
By the way, I think you mean 1.5 Watts, not 1.5 Amps.
   / Harbor Freight Solar Panel Battery Charger #3
Yeah that would be a big solar charger for 1.5 A at 12V....:cool:
   / Harbor Freight Solar Panel Battery Charger #4
1.5A @ 12V is only 18 watts. That is not a very big charger. Trickle charge for a battery is usually around 1/10th of it's amp hour rateing. A car battery is around 50 or so amp hours, so a 5A charge rate would be concidered a trickle. 1.5A is only a maintainer...
   / Harbor Freight Solar Panel Battery Charger #5
You could hook the solar cell up to one of those highly acclaimed hydrogen generator systems and run your cars and trucks off it without ever having to buy gas again. Be careful, it would put out so much the Saudis would want to put you out of business. I read all this on the innernet so it must be true. I bought a bigger one for 1/2 price at TSC. I'm afraid to use it on the car because it would probably blowed up... :D
   / Harbor Freight Solar Panel Battery Charger #6
It would be about 1ft x 3ft. To me that's a pretty big solar panel:)
he said it was $12- so that means unless he found a heck of a sale it is the 1.5 WATT one......the 15 watt ones are closer to $100 and MUCH larger.:rolleyes:
   / Harbor Freight Solar Panel Battery Charger #7
1.5 watt $15
linkly linky
Harbor Freight Tools - Quality Tools at the Lowest Prices
   / Harbor Freight Solar Panel Battery Charger #8
dumb question....do these things really work?
I've got a backhoe (industrial) and seems my battery is always dying over time. Either from lack of use or perhaps a charging issue. I've thought about buying something like this to clip onto the battery leads when not in use.
Should I?
   / Harbor Freight Solar Panel Battery Charger #9
Should I?
I'd use a "battery tender". They are reasonably priced and work well. I use one on my TLB (along with a battery quick disconnect).
   / Harbor Freight Solar Panel Battery Charger #10
Should I?
I use them on a few tractors.. yes.. they do put out electricity when in sunlight.
soundguy
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
Ryobi Weedeater (A51573)
Ryobi Weedeater...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
