HardiPlank or Vinyl?
   / HardiPlank or Vinyl? #1
widefat
Platinum Member
Central Va
Kubota L3200 Husq GT52XLS Husqvarna LC121P Husq 455 Rancher Stihl FS90 Stihl MS170 99 Ram 1500
Cost aside, what would you choose for siding? HardiPlank or Vinyl?
I was leaning toward Hardie, but I have heard enough about it, even when installed correctly, to wonder if it is all it is purported to be.
   / HardiPlank or Vinyl? #2
I built a temporary shed 8-10 years ago. :rolleyes: Used Hardi 4x8 panels for the siding and since it was "temporary" I did not paint the material like I was supposed too. Seems to be holding up just fine for a 8-10 year old "temporary" structure. :laughing::laughing::laughing: Carpenter bees are doing a job on the rafters though.... :mad::mad::mad:
Cutting the stuff is a PITA. There are special blades or shears to cut the stuff which I would buy if I had a big project.
Later,
Dan
   / HardiPlank or Vinyl? #3
Here's my house with Hardiplank (brick red) half way up the sides and Hardipanel (off white) the rest of the way. Photo was taken 10 years after the house was built. Only painting done was on the white trim at about 9 years.
No problems with that siding.
Good luck
   / HardiPlank or Vinyl? #4
Hardi Plank is VERY durable and holds paint better than anything, if you even need to paint it. I worked on a major remodel where Hardi Plank was being installed...I asked the homeowner why he sided his garage first...he said he put the Hardi Plank on the garage 10 years ago and that's why he was putting it on the house after seeing how well it held up.
The only "fault" with Hardi is that it does not cast a shadow due to it's thickness compared to other siding that has more of a profile.
   / HardiPlank or Vinyl? #5
As a former vinyl siding installer, I can tell you vinyl is crap. My house is brick, but if it were siding, I'd go Hardie board. Your only downside is paint every 10-15 years or so.
   / HardiPlank or Vinyl? #6
Hardiplank is the only way to go. Use shears to cut it, sawing creates a lot of unhealthy and abrasive dust. Our house was originally sided with LP lap and sheet siding, it was supposed to be improved and better than the earlier versions. Despite meticulous maintenance and painting it started to fail within ten years or less. Hardi siding was not yet available when we built. We resided our house in a couple of stages, the single story end I did myself and I hired a contractor friend to do the two story end, my better half did not want me on that tall a ladder.
My sister in law had vinyl installed on her house, looked cruddy and cheap up close and rattled when it was windy.
Just make sure to install it correctly and caulk it as soon as it is installed, I would paint it as soon as the weather permits cause I think the primer paint is not very attractive.
Shears are the best way to cut it, I have used both shears and circular saw, shears are much cleaner and easier!
Just remember the first rule of projects - For every diy project you deserve a new tool(s), it is part of the overall cost.
   / HardiPlank or Vinyl? #7
I went the vinyl route laste year. Big cape with dormers and a metal roof. Chose it based zero maintenance or paint requirement ( the only house I ever owned that I DIDN'T ever have to paint). Only been a year, but for me, its a slick way to go.image.jpg
   / HardiPlank or Vinyl? #8
trick question..?
vinyl is the pits...IMO...
   / HardiPlank or Vinyl? #9
trick question..?
The cement board (Hardi Plank) falls apart in wet situations. Such as shady inside corners, decks and splash off dormer valleys etc.
If you can keep it dry, it looks good. Here in VT, it's 10 years at BEST even with frequent touch up painting. (South walls do great!)
   / HardiPlank or Vinyl? #10
To me, if cost is not a factor then Hardi is far superior. I had vinyl on my last house, and while it held up perfectly well and was low maintenance (other than power washing) it looked cheap. It was also noisy whenever there was wind (vinyl must be installed loose enough to expand with temperature changes). We have Hardi on our new house -- combination of lap siding and vertical board/batten -- and it looks outstanding and gives the home a totally different "solid" feel.
Cal, are you sure that is Hardi? Because I have left some unpainted Hardi scraps stacked outside for about 12 years now and they haven't changed a bit, much to my surprise. I figured without paint it would eventually deteriorate somehow.
2016 Isuzu NPR-HD 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
40' CONTAINER (A51244)
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
