Has anyone used a boat motor elec/hyd cylinder to make power steering on an old tract
   / Has anyone used a boat motor elec/hyd cylinder to make power steering on an old tract #11
This may sound a little rude-I don't mean it to be...but if you admittedly don't know enough to get your existing system up to par how do you expect to add a new system and have it functioning safely?
My thoughts exactly.....:(
   / Has anyone used a boat motor elec/hyd cylinder to make power steering on an old tract #12
Leejohn: Thanks for the info. I'm not aware of the system you described. The one I have is made by Cook Manufacturing in Oklahoma and works differently. Either way, I would not recommend it for an easy power steering system.
Jobguy: Have you considered a larger diameter steering wheel? It doesn't take much to give you extra leverage. Do you remember how big the steering wheels on cars were before power steering?;)
   / Has anyone used a boat motor elec/hyd cylinder to make power steering on an old tract #13
Jim yes that CMC power lift is alot different and as you said either way no good for power steering. The ones I was talking about were the stern drive cyls.
   / Has anyone used a boat motor elec/hyd cylinder to make power steering on an old tract #14
i agree completely. if the oem hyds aren't working.. or not known how to work.. then fabbing up a new system from scratch is gonna be even more of a stretch.
I'm going to look for a larger steering wheel and see if I can find one of these tractors with factory power steering to see how the mfg did it. Maybe find original equipment. All of you have been very helpful. Thanks
wdchyd: Now that looks interesting. Might even be within my capabilities. Thanks
2014 Ag Spray Schaben Sidedresser (A55301)
2014 Ag Spray...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
