sightsear
- Joined
- Feb 12, 2006
- Messages
- 6
- Location
- north carolina
- Tractor
- 1940 ford 9N W-FEL/1997 Kubota L35 W-FEL&BH
was digging out a pine stump with my L35. Had RPM's low due to stabilizers being close to the "pit" (two stumps at once, they were about 18 inches apart), didn't want the machine to move due to BH tug. Relief valve activated frequently for this process. The big stump was positioned such that the boom would rest on it while addressing the area behind it, I figured no problem, I'll move when I have to. Don't know it this was part of the cause, hadn't done that before. Heard a noise behind me around the FEL control area, (that also in the area where the hydro pump lives a bit forward tho). Rattel sucking type noise, gears reluctently changing shape noise..not out of the question I guess. Both FEL and BH no longer worked (they worked great previous). Got the book out.
I've got the machine at auction about a month ago, and put about 50hrs on it. While initially checking things over and greasing, I saw the hydro fluid was over full, drained about a gallon out. That put in right on full. Checked it a couple of times since and still showed right on. And had about 30 plus hours of perfect operation since the drain. Checked when it failed and the level was right at the add mark. Replaced what I took out.
loosened the lines (while rinning at idle) on top of the pump to see if air may be in there. The first one I did I saw what looked like white paint chips come with the fluid. Not so with the second, just fluid. Obviously had pressure, both FEL and BH were resting on the ground.
My question, did I break my trusty steeds pump. Or could I still have air. The noise, was quickly followed by loss of both FEL and BH function. Power steering and trans seems fine.
Machine has about 1600hrs, about 50 of them are mine and loved every minute. Want more. And it's sitting sidways in my driveway with the BH dipped in a 5 or so foot pit (I can still get around it OK) But I'm worried the neighbor will tease me it stays there too long.
Jim
Jim
