Heavy Duty Top Link installed on L2800...
   / Heavy Duty Top Link installed on L2800... #1
teg
Super Member
nowhere
s
I was not going to post this mainly because I don't think kubota sell them anymore. Heavy Duty Top Links were to help support the tractor's top link when using a 3ph backhoe (before they had a sub-frame). kubota figured out that they had to have the sub-frame and this became obsolete.
I bought mine in the old days of the (really) jerky 3 point hitch. I was lifting very heavy loads and thought that sooner or later the top link would not be able to handle the shock loads... I finally had my valves replaced so I didn't install it. Since I just got hydraulic top link (5 years later), I thought... why not install it.
One side note, if a few of you can look under the seat area and see what condition your hydraulic breather tube is in... it might help others. I think mine was made out of the same crap (rubber) that the return hose was made of (cracking/falling apart). The tube was split and not on the breather hole. The hole had a plug of grass (who knows what else was sucked in there). Just a heads up.
Photos... There were only 4 bolts under the seat, I add two more. I bought all new bolts that were 1/4" longer and used Blue Lock Tight on them. I welded the old 3 point brackets onto the top link. Last photo is the location of the breather valve, I don't have a photo of the split/cracked one - I used the end tip of the old one shoved into a fuel line hose. (just a heads up... the seat is removed in the last photo)
   / Heavy Duty Top Link installed on L2800... #2
Looks good, I have been thinking about installing the heavy duty top link bracket on my B3200 if I can find one. I'm going to be running a post driver on mine so I figure the extra weight/jarring isn't good for it.
2017 Kia Optima LX Sedan (A50324)
2017 Kia Optima LX...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
