Hedge trimmer owners, what do you use in the gear box?
   / Hedge trimmer owners, what do you use in the gear box? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I recently bought a hedge trimmers and was abusing it. Long story short I nicked a few teeth and had to take it apart to file them. The gear box was filled with a thick grease and was mostly pushed out of the way of the gears. I smeared some white lithium grease in it and between the blades and put it back together. It now runs better than ever, but I’m wondering if I should take it back apart and fill with something else. This wasn’t a garbage unit either. It was Red-Max.
   / Hedge trimmer owners, what do you use in the gear box? #2
They probably use a NLGI 0 or 00 grease, aka "flowable grease" or "cornhead grease"
Aaron Z
It didn’t look that flowable.
   / Hedge trimmer owners, what do you use in the gear box? #4
Gun grease. Echo has a zerk on the box for regular service. Just a few pumps and you are good.
This one has a bolt to take out and put grease in but no zerk.
   / Hedge trimmer owners, what do you use in the gear box? #6
Lube like 00 is not available for typical grease guns...it usually comes in a funnel tipped bottle like regular gear oil...
There’s no place for grease to escape. I think a zerk would be a bad idea anyway.
2022 Bobcat ZT3000 52in Zero Turn Commercial Mower (A49461)
2022 Bobcat ZT3000...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A51039)
John Deere 946...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
