Help changing hydraulic fitting
/ Help changing hydraulic fitting #1
Tibbits
Bronze Member
L3430 GST, BX1500
One of the quick release fittings on the FEL control box needs to be replaced. The FEL is not mounted and I think the way to do this is:
-engine off
-eye protection
-move FEL control lever around, all directions
-wrench off fitting slowly in case there is any pressure
I don't want a hydraulic skin injection! Could someone verify the above will be harmless?
/ Help changing hydraulic fitting #2
That's it...If the engine is off then there is no risk of fluid injection.
Thanks kennyd. I was a little nervous about this one.
/ Help changing hydraulic fitting #4
procedure is about right. engine off, crack line slowly with 2 wrenches. one to hold nut and other hold line from turning to prevent damage.
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2022 EZ-GO ELITE...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
