Help diagnosing problem with Kohler M20QS
   / Help diagnosing problem with Kohler M20QS #1
jaghobbies
I have a Bolens tractor with a Kohler M20QS (20 horse) engine. The problem is that the engine has low compression and is low on power. It will also use oil when under a heavy load. I have a 48" deck and it will stall the engine if I mow through grass that is too high.
I took it to a local dealer and they did their leakdown tests and some other tests that I can't remember and they said the only thing they could find is the tractor is low on compression and has a clicking sound that comes and goes. They don't know why the compression is low.
They say the next step is to tear it apart and check it out which will cost at least $1000.
I was wondering if anyone had a second or third opinion before I do anything stupid.
Thanks,
Jim
   / Help diagnosing problem with Kohler M20QS #2
How are the maintenance items, clean oil, good crankcase vent, is engine sludged up? Did they say what psi the compression actually was, valve clearances, plugged muffler, old age?
   / Help diagnosing problem with Kohler M20QS #3
jaghobbies,
I would say if you took it to the dealer and had it tested did they say it might be the rings. Does it smoke when under load more than normal. Did you do a wet compression test on the engine. From my stand point at this time it is the rings. But there is also the heads that need to be checked clicking my be a valve not closing all the way. I would also check other dealer 1000.00 for just tear down is high to me. Valve, head gasget, bad head or rings. http://www.jointsystems.com/kohler_specials.htm
Check this link a new M20QS is only a 1079.00 at this price I get some local school kid shop class to put in a new engine before I pay 1000.00 just to look at it and tear it down Hope this help. Sam
The engine oil has been changed every 25 hours or so. No sludge in the engine. I haven't checked the vent yet. They just said the compression was under spec. I'm going to recheck it when I get it back.
I was thinking is was probably too much valve clearance. I thought this would cause a clicking and low compression. I'm going to check that out too when I get it back.
Not sure what tests they performed but they didn't think it was the rings. Didn't really say what they thought it was.
Thanks for the help,
Jim
   / Help diagnosing problem with Kohler M20QS #5
come to think of it I had a race car engine do the same changed the fram oil filter it came backe to life. I do not use fram any more Sam
   / Help diagnosing problem with Kohler M20QS #6
I'll try some of the other forums but here are the results of the tests:
Compression 75-80 psi
Manometer reading 20"
Leakdown - middle of good reading
Jim
   / Help diagnosing problem with Kohler M20QS #9
Seems like if they did a leak down test they could find out what general area the leak down is coming from.
Air hissing in the carb/intake--> intake valve
Air hissing in the muffler--> exhaust valve
Air hissing from the crankcase vent--> rings
Again this just getts you in the general direction.
Of course the cylinder needs to be at TDC.
$1000 to find out why a 20hp engine has low compression...I'm in the wrong business /forums/images/graemlins/blush.gif!
   / Help diagnosing problem with Kohler M20QS #10
</font><font color="blue" class="small">( ......................
Thanks,
Jim )</font>
I am almost certain that they were referring to tearing it down and rebuilding the engine, not just tearing it down to inspect it. I believe this is a case of the owner of the engine, not comprehending the entire conversation as to costs. This is also a common problem, people saying one thing and the person hearing the words, misses some of the important details. If the shop did in fact, figure $1000 to tear down the engine for inspection, I would say that they were not qualified to do the work, because it would take them too long just to do the inspection. I am assuming that their hourly rate to be about $50 and it won't take 20 hours to tear down that engine. Possibly two hours would be more likely, and I am being generous with that figure. I suggest that you go back to the shop and question them further.
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
KENWORTH W900 (A50854)
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2006 KENWORTH T300 SERVICE TRUCK (A51243)
2006 KENWORTH T300...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
