Help!! how to fill the rear end???
   / Help!! how to fill the rear end??? #1
001
United States
craftman
Hello
I have owned sears tractors since the 70's...
I now own 2... My older tractor I went to pull her out of the shed and she no want to shift... at the end of last year I seem to remember it shifting a bit hard, I thought it might be related to colder weather...
so I have looked for a filler and found nothing.... :cool2:
I do still have my first and 2nd tractor and I think my 2nd tractor is the same rearend...
   / Help!! how to fill the rear end??? #2
There should be 2 plugs, one about half way up and one on the top. Clean it off real good and take a look. You can always post a pic.
   / Help!! how to fill the rear end??? #3
got a model # of tractor or pic ?
Yes I did clean it real goor and see nothing it is a 2002 T1000
I think the model # is 179-271652 will have to check in the am
   / Help!! how to fill the rear end??? #5
Is it 917? not 179 for the first three. If so, there is no fill plug on your trans. Those units are loaded with bentonite grease. The shifter fork could be binding or the shift keys sticking.
Yes you are right 917-271652
thanks
Thanks!
That what I tought (no fill plugs) I did oil the slector balls/springs
I guess when it gets really really bad I will have to chage it with the one from my 1992 craftman tractor.. they look the same bolt pattetrn....
right now I can still make all/most the foward speeds
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
