Jtullis13
Platinum Member
Ok so I have several questions for the Hydraulic Specialist in this forum. I have a Yanmar 2210d that has a Koyer 120 loader that has a Dinoil valve on it. Initially the loader was plumbed from the gear driven hydraulic pump on the engine. The loader valve outflow powered the 3point, and the 3 point dumped back into the sump. Everything worked good. I wanted to add a PS kit from Fredricks/Hoye. This is how it was suppose to be plumbed, hydraulic pump to a divider valve (FRC51), the divider (FCR51) has 2 outflow ports that can be regulated by an external knob. One outflow supplies the PS, the other outflow supplies the loader valve. The loaders outflow still goes to 3point. The loader function and PS function are mediocre set up this way in my opinion, no offense Aaron. I was hoping for more function of both, but I also realize I haze a small tractor with small hydraulic pump. Anyways my thought was to plumb it the initial way it was, pump to loader, loader outflow to 3point, use the Power beyond to supply FCR51 valve which powers the PS, the other port on the FCR51 goes to sump. This way I now have individual 100% PS function and 100% loader function as long as I am not using the loader and PS at the same time. The loader takes priority over the PS. So when using the Loader I loose PS function, I am fine with that. The question is, my 3point no longer works unless I use my loader at the same time. So is the power beyond taking the flow from my loader valve outflow and not letting my 3point get any fluids while operating?? And by activating my loader I know stops flow from the power beyond, but does that allow the loader valve to direct fluid to the outflow of the loader valve to my 3point now?? Is there any way to get my 3point to work with the power beyond set up this way and not having to use the loader to get the 3point to work? Also could I be causing any back pressure by having it set up this way? Or causing any damage to anyting? Any help would be appreciated!! Thanks ahead of time! I tried to upload a diagram but wasn't sure how to get it to load, sorry.
