Help me identify This MiddleBuster
   / Help me identify This MiddleBuster #1
KingDelta5
Denham Springs Louisiana
John Deere 790 1949 cub 1975 cub 1948 super A 1950 super A 1967 140 High Clear
Anyone Know the Maker if this MiddleBuster ????? Thanks for any help MiddleBuster1.jpgMiddleBuster2.jpgMiddleBuster3.jpg
   / Help me identify This MiddleBuster #2
Not real sure just guessing trying to help but I think it might be made by/for a Farmall. :confused:
Boone
   / Help me identify This MiddleBuster #3
Looks like a cultavator shank with a potato plow on it
Yes it does :) It is about 4 foot tall when you stand it up.
   / Help me identify This MiddleBuster #5
The cultivator shank could go on any number of machines or implements that use a square tool bar. It would take a large machine to pull that plow point at any depth. The plow point appears to be two welded together. Looks like a home brew implement. I doubt that the tool bar clamp could withstand the torque if that plow was pulled very deep or in heavy soil as in a middle buster/subsoiler. It may have been part of a multi-row potato or peanut harvester used to plow the potatoes or peanuts out of the ground.
Nothing is welded Every thing is bolted ! I bought this to have a middlebuster ! I think the way it was hooked to whatever it was hooked to was from the toolbar clamp then again up the shank toward the toplink ! The shank is forged and tapered . I would wonder what this beast would cost to build today ! I bought this to attach to my toolbar to make small drainage ditches ond for potatoes and the like ! Thank you very much for reply :)
   / Help me identify This MiddleBuster #7
Attached to a 2" square toolbar I'm sure it will do what you describe just fine. The plow point appears to have a seam in it so it looks like two welded together. It will be a tough pull for a 30 hp tractor trying to pull it at much more than potato hill depth but it should plow potatoes just fine.
Do you have a 2" square 3 point toolbar to attach it to?
Yes I have several tool bars ! I try to collectand use good old farm equipment ! And I agree It being hard to pull ! That is not my purpose for it ! Mainly to scratch shallow drainage ditches in the fields !This plow is completly forged bolted together and also has 2 big rivets about 3/4 inch diameter . I no dought date it to the 50s but it could be a good older ! I like to collect and use old farm equipment ! They represent a era when products were a major investment to the buyer and the products were built with no built-in obsolescence ! We for sure will not see such again ! I recon farming must be done differently in different places and by different people . Other than knocking down a row or scraping a shallow ditch I have no idea why anyone would bury a middlebuster to the hub and pull till maximum smoke !
Wolverine Fork Extensions (A50515)
Wolverine Fork...
HOMEADE 8' X 20' GOOSENECK FLATBED TRAILER (A51243)
HOMEADE 8' X 20'...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A51242)
2006 CATERPILLAR...
Case IH 2388 Combine (A50514)
Case IH 2388...
MAHINDRA 5545 TRACTOR (A51243)
MAHINDRA 5545...
