Help needed, 2 bottom Case plow
/ Help needed, 2 bottom Case plow #1
russt66
Emery, UT
Kubota 4050
So, I have broke two parts on my plow and need to identify the model and hopefully find some parts. Part reads T1207. I attached pictures of the unknown case plow nad the part.
thx
/ Help needed, 2 bottom Case plow #2
Do you see any serial tags on it? The part in the second picture attaches to the turning shaft up near the tractor. I am not sure of its purpose but it looks like a stop of some kind. I've never dealt with a plow like this before.
I looked it over really good. No serial number or model number that I can find. What is left of one sticker mentions to block the implement up when unhooking it. The other is what is left of the Case name and where it was made. The picture in the middle you can see the keystock wedged and broke the hub. You can see where it attached in the first picture ( i squirted the springs with wd-40). The chain hooks to the rod in the senter of those springs then to a geat that rotates the plow over. I would have welded it already if it wasn't cast.
/ Help needed, 2 bottom Case plow #4
You can weld Cast iron with special rod and heat the cast iron up, or Braze it.
I prefer brazing.
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
2022 John Deere R4023 (A64119)
2022 John Deere...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
John Deere 5090GN (A60462)
John Deere 5090GN...
