HELP NEEDED
   / HELP NEEDED #1
tward8987
the tracks have jumped off my CASE CX36B mini excavator and i need to know haw to get them back on ASAP
   / HELP NEEDED #2
My Volvo uses cylinders pumped with grease to set the track's tension. They say to remove the grease fitting that you pump the grease into so the cylinders can be compressed to give you slack to put the track back on. Guess you use some sort of clamp to do so. No idea if your's are same set up but think the grease filled cyls are right common.
   / HELP NEEDED #3
Using your stick over to one side, lift the track off of the ground.
With prybar or crowbar get the track engaged onto the sprocket
Gently using a prybar add pressure and lever or guide the track back onto the idler while a helper engages traction to that track.
Generally the track will pop back onto the idler wheel.
Easier if you can release the pressure on the tensioner.
In future when turning use your stick to lift the inner track off of the ground all while driving the outer and gently turning with the stick.
Sharp aggressive turns with right track in reverse and left in fwd will detrack just about any tracked machine if everything is not 'just perfect'. Also those side loads are hard on the whole undercarriage components.
I have watched a good operator turn an old worn machine 90 degrees when the tracks were so loose and worn that the track chains sagged almost 6-8" (rubbed on the tensioners) with the above technique.
Good luck!
   / HELP NEEDED
thanks so much guys i dont know anything about this stuff my husband and my father and law just needed a few ideas and hints... i appreciate the help
NEW Land Hero Mini Excavator (A48289)
NEW Land Hero Mini...
Pump (A46683)
Pump (A46683)
2012 Case 590 Super N Extendahoe Loader Backhoe (A45336)
2012 Case 590...
New Wolverine Skid Steer Ripper (A48289)
New Wolverine Skid...
Lockwood 2 Row High Capacity Harvester (A47369)
Lockwood 2 Row...
John Deere 8320 Tractor (A47369)
John Deere 8320...
