HELP on fuel air block
   / HELP on fuel air block #1
bc realtor
Vancouver Island BC
Antonio Carrero TTR4400
I was just doing the change of the fuel filter and forgot to refill the bowl. Started up and after 10 seconds or so the motor stopped. I presume I have a air blockage.
Do I just crank the engine till starting or do I have to bleed the system?
The engine is a three cylinder yanmar on an Antonio Carraro TTR4400.:drool::confused:
   / HELP on fuel air block #2
Unless it is self bleeding, it sounds like you will need to crack the lines open one at a time and bleed the air out of it. The 3cyl Yanmar on my JD 790 is self bleeding, but I don't know if it would recover from having that much air introduced into the fuel system without a lot of cranking. Good luck....
Thanks, I cracked the lines and cranked it till it was all fuel. started up and no more worries. thank you once again.:thumbsup:
2025 Gold Mountain 12ft X 20ft Single-Truss Steel Carport (A48082)
2025 Gold Mountain...
Grapple, Approximately 75mm pins (A47371)
Grapple...
LEUS XR3037 4WD Tractor (A49251)
LEUS XR3037 4WD...
Forks (A49251)
Forks (A49251)
New Holland 273 Hay Baler (A49251)
New Holland 273...
2009 New Holland TD5050 Agricultural Utility Tractor (A46683)
2009 New Holland...
