diesel lover
Platinum Member
- Joined
- Dec 21, 2013
- Messages
- 643
- Location
- whites town indiana
- Tractor
- Ferg. To 20, 1956 Massey F. MF 25 diesel, Ferg. 40, 1944 John D. A, 1965 cockshutt 40,
Hey guys. Need some help. I have a 56' Massey MF 25 and from what it sounds like the thermostart/ fire lit intake manifold heater that runs off diesel fuel does not always ignite. I was going to look further into it down the road. Tractor is in Michigan and I'm in Indiana. Sometimes it does not ignite from what it sounds like. I was going to check wiring to it/ clean connections/ rewire but how hard is it to unscrew the element from the manifold and replace it in one piece as preventive maintenance as these where out just like a glow plug. I was thinking soak it and soak it in pub blaster and it should come right out. Should not be hard to service/ repair.
*How long should the key be held? I was thinking 20 or 25 seconds . Turn over engine for 20 seconds and relight the manifold heater to give time for starter to cool. This is how I usually do it and tractor starts right up in +20 deg weather.
* block heaters did not fully come around till 1940 from what I read. Does anyone know if this engine has a easy to get to freeze plug? Otherwise I will install the highest watt radiator hose element. As a truck mechanic I have experience with block heaters just did not know if my engine had an easy access freeze plug. I didn't find one over a year ago.
*This tractor has a 107 cubic inch 4 cylinder Perkins engine. Does this mean this engine model is a 4.107 found in forklifts and other equipment? Mine has a rotary fuel injection pump.
* what is the fastest "killer" of block heaters? They do break and have to be replaced. Does it hurt one to start an engine while its plugged in and coolant is circulating on the HOT element? I have read that putting one in a space too close to cylinder walls etc will cook them as they overheat. Have a freeze plug block heater in my 97 f150 and it works swell!
https://www.youtube.com/watch?v=nthWkCxnnEQ&feature=youtube_gdata_player
Test of a thermo start
