Help: Questionable loader on used tractor
   / Help: Questionable loader on used tractor #1
tomd999
Platinum Member
Viva Manchvegas!
'10 3320 cab
Hi,
I'm checking out a used Deere 3320 with a 300cx loader/4n1 clamshell bucket.
When I tried the loader function the "lift arm" circuit functioned normal however the "bucket" circuit was a bit odd. When you dump an empty bucket, (holding the lever in the dump position), it dumps qiuickly until it's at about a 45 degree angle to the ground, then dumps at what I would consider normal speed until it gets to 90 degrees, at this point it stops rotating rearward and appears to hang/swing freely like it's not connected to the cylinders for about 2 or 3 seconds and then finishes the dump stroke quickly to the stops with a bang. Throughout this movement, I kept the loader control in the same position. It does this as many times as I move the bucket through it's range of motion.
What's wrong with this loader? I don't want to buy a headache.
Thanks,
Tom
   / Help: Questionable loader on used tractor #2
Nothing is wrong. You are pushing the joystick to far and it's going into the Regen mode. It will act funny when the bucket is empty.
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
