Help settle an argument: batteries
   / Help settle an argument: batteries #1
apewrangler
Vicksburg, MS
My dad has a JD 4230 and an IH 454. They both use 2x6V batteries that never last long, just don't have enough juice in the winter, and are getting increasingly harder to find.
I've tried to talk him into just using a single 12v battery for each tractor that will last longer and be much easier to come by, but he insists that buying a new 6v battery or two every year is the best way. Does father know best?
   / Help settle an argument: batteries #2
The 454 could easily start with a high CCA 12 volt battery. The Deere can be converted to two 12 volt group 31 batteries by replacing and reconfiguring the cables. He will think he has a new tractor.
Edit. I see you are in Mississippi. You can probably get by with a single Group 31 battery in the Deere providing it has a minimum of 950 CCA.
   / Help settle an argument: batteries #3
A 12V wet cell is no more than two 6V batteries in a common case.
   / Help settle an argument: batteries #4
As a practical matter there have been many dozens if not hundreds of such conversions. I’ve never heard or read of anyone going back to two six volt batteries. Two 6 volt Group 5D batteries rated at 850 CCA wired in series equals 12 volts and 850 CCA. Two 12 volt Group 31 batteries rated at 975 CCA wired in parallel equals 12 volts and 1950 CCA.
   / Help settle an argument: batteries #5
I have found that grp31 batteries are a real bargain for the output they provide. It probably has to do with the fact that most highway semis has 3 or 4 of them so they make a bunch of them and it's an item the fleets price shop. It does pay to shop as places that deal with truck people have better prices.
   / Help settle an argument: batteries #6
Two 6v batteries wired in series is a 12v battery. If dad is replacing only one, that will drag the new battery down and result in shorter life.
Are the 6v batteries being replaced with golf cart type batteries (i.e deep discharge) or starting batteries?
Two 6v batteries is not the issue. I'd be doing some trouble shooting for parasitic loads that are causing a constant discharge. You can replace with a single 12v battery, but if the issue is not corrected, the 12v battery won't last long either.
   / Help settle an argument: batteries #7
There is no good reason for sticking with 6V batteries.
However, I agree with Jaydee325. The real question is, why are his 6V batteries only lasting a year? Time for some trouble shooting as to what is going on here. Is there a drain on the batteries when not in use, or is the tractor unused for extended periods of time? (all lead-acid batteries self-drain over time, and the process is accelerated in warmer temperatures.)
In addition, I'd hook the batteries up to a battery maintainer when not in use, to prolong life. I've had very good experience with the BatteryMinder brand. You can buy direct, or find them at Northern Tool: BatteryMinder model 1500 for a lower-cost model (1.5 Amp, desulfating, temperature compensated), or model 128CEC1 for a more deluxe model (selectable 2/4/8 amp charging, desulfating, temperature compensated, charge profiles for Gel, flooded lead-acid, and specialty AGM). They also make solar powered charger/maintainers, if the tractor is stored in a location with no power. While their cheapest model, the 12117 has been mostly discontinued (now only sold through Northern Tool) does a decent job and includes desulfating, I don't recommend it often since it does not include temperature compensation - which can be an issue of your tractor is stored in hotter or colder climates). There are other good brands, this is just the one I'm most familiar with.
They make a 6 volt charger, but that's not the way I would be going with this.
   / Help settle an argument: batteries #9
I totally agree. Find the reason the batteries are going bad. Any battery whether 6v or 12v in a diesel tractor should last at least 4 years as long as your charging system is working properly. Your system could be overcharging the batteries and burning them out just as easily as it could be failing to charge. An ammeter should tell you if the charge is doing correctly or if the needle is constantly in the 12-14v range, the voltage regulator might be bad. After running a while to recharge the starting drain, the needle should return to near zero.
Yearly replacement of battery/batteries) is not the answer.
   / Help settle an argument: batteries #10
Find and repair the parasitic drain or overcharging condition. Keep the top of the battery as clean as possible as a film of dust and dirt WILL conduct electricity and discharge the battery.
Don't believe me?? Take a filthy battery, place the + lead of a VOM on the positive post and the - lead on the dirty battery top and see what the meter does.
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2015 Chevrolet...
Bush Hog PT 10' Mower (A47307)
Bush Hog PT 10'...
1996 Toyota Camry Sedan (A46684)
1996 Toyota Camry...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A45677)
2012 VOLVO VNL...
Bobcat Bobcat Bucket (A43476)
Bobcat Bobcat...
2022 Mack MD Rollback Truck (A46683)
2022 Mack MD...
