Help TC35 wont start and need to move concrete tomorrow!
   / Help TC35 wont start and need to move concrete tomorrow! #1
mpilihp
Jefferson, ME
Pasquali 988
So Im building a Quonset hut and need to pour the footings, Ive got all the concrete in the garage dry and need to move it to the site but now the tractor wont start. It intermittently started a few times and now wont at all. It appears to be a safety switch that wont let the starter engage.
Wiggling the FWD/RWD level would get the starter to engage so I think its that safety switch, does anyone know where it resides and if I can bypass it to get by for tomorrow???
Thank You
~ Phil
   / Help TC35 wont start and need to move concrete tomorrow! #2
Can you look under the fender and see the linkage for the lever? On my TC33 the switches were there....different tractor, I know. Sometimes twigs and dirt would get to them.
Hi thanks Ill look there first, was late when I finished trying to get ready yesterday for today. Up early so I have time to tinker on it. Hopefully they did things similar and they are there.
THank you!
~ Phil
Hi thanks for the link to the doc, I will review that. What I did find is I couldnt see any switch/s under the fender or on the transmission. It started fine a few times and then not so I kept it running all day to get my work done. I also suspected there was a switch on the seat as it didn't seam directly tied to moving the gear level. The seat switch was already bypassed by the prior owner.
Im now suspecting the actual ignition switch but will review your doc and see if there is any other indicators for me to look at with it.
Thank You!
~ Phil
   / Help TC35 wont start and need to move concrete tomorrow! #6
Thank You!
~ Phil
The ignition switch is common problem as well as I had to replace mine early on, good luck:
https://www.tractorbynet.com/forums...ow-plug-problem-fixed.html?highlight=ignition
   / Help TC35 wont start and need to move concrete tomorrow! #7
Thanks for the link thats a great short term idea. Ill look into it!
Thanks, I do think this may be it but the component pdf the other person shared shows there are safety switches under the fender, must be a cover under the fender to get at them.
So it does show safety switches under the fender area. THere is one bolt under there that must beholding a cover on, Ill have to dig into it. Funny looking down into the slot where the levers come out I cannot see any wires or switches under there.
Thanks!
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2015 Nissan Sentra S (A50324)
2015 Nissan Sentra...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
