Help Understanding Tractor HP and Prices
   / Help Understanding Tractor HP and Prices #1
adamjthompson86
I'm a n00b when it comes to tractors. I'm confused as to why tractors are so expensive for the amount of horsepower you get.
For example, you can buy a 20+ horsepower riding lawn mower for $1500 or so. A 20+ HP utility tractor with mowing deck is going to cost you about $15K - 10x!
I realize the tractor is built much more ruggedly, has a PTO, diesel engine, larger wheels, and other features - but 10x the price for the same horsepower seems very expensive to me! Why so expensive?
One related question I have is - are the HP ratings really accurate? Is a 25 HP utility tractor really no more powerful than a 25HP riding lawn mower?
   / Help Understanding Tractor HP and Prices #2
Well, I have two guesses.
1- the lawnmower type horsepower are wrong and that's why the new class action suit is in action.
2- The horses used to figure out lawnmower type tractors are Shetland ponies and well, you get what you get. ;)
   / Help Understanding Tractor HP and Prices #3
Gas engine HP ratings can be very much exaggerated for marketing purposes. The engine may be able to make the advertised HP, but engine longevity at the advertised rating may be very short.
Tractor engines may be rated more realistically, but even then the tractor's engine HP is gross (no loads, which means no transmission, drive shafts, axles, etc.). Engines being rated for gross HP may have required accessories such as fans, waterpumps and perhaps an alternator/generator. PTO HP ratings are a more realistic measure of what the tractor can do. On large tractors, the rating may be drawbar HP (pulling power).
Sticking with Compact tractors (for sake of discussion),to get the torque transmitted to the wheels and implements requires gearing that just isn't cheap to produce, especially considering the relatively small numbers. To contain the gearing requires robust castings for long term durability. Castings are cheap compared to forgings and machined components, but that doesn't mean they're cheap in price.
Then there is the machining required to allow the castings to perform as gear carriers or engines...substantial costs.
And, a Compact Tractor needs weight to put this power to the ground and some rather expensive tires to move that power. A typical Compact Tractor with no FEL weighs in the neighborhood of 2000-2500 lbs. Thats easily 3 to 4 times the weight of a lawn tractor.
All of these higher grade components add to the longevity of the compact tractor which, with required maintenance, will last thousands of hours before overhaul. It's unlikely you'll see those hours with a lawn tractor...and after a number of hours, that lawn tractor is most likely a throwaway (no worth rebuilding).
If you put a chain between a 20 HP Compact Tractor and a 20 HP lawn tractor, then did a pulling contest, the compact tractor would pull that lawn tractor easily.
So, if you need to cut your lawn, buy a lawn tractor for $1500. If you need to do more serious work, be prepared to spend 10 times that for a compact tractor.
   / Help Understanding Tractor HP and Prices #4
Welcome<
I have a 31hp Kawasaki Badboy Zero Turn Radius lawn mower. That being said: a 30 HP New Holland TC 30 for example would put it to shame completely for any and all purposes that your mind could conceive or your imagination could dream. There is no comparison when speaking to HP on mowers vs tractors. I do not know what causes this extreme difference but my guess is the ratio of torque; transmission; tire size and weight of the tractor vs the mower. The price difference is well deserved and earned on every hour used in the field.
Hope this helps.
Adam
   / Help Understanding Tractor HP and Prices #5
Tractors are an end to a mean. If you have to run certain implements the tractor has to be sized to run these implements. Dollar per horsepower is determined by what you need the tractor to do.
   / Help Understanding Tractor HP and Prices #6
No comparison. A 25 hp Kubota is worth 20X a 25hp MTD rider. They both say 25 hp but they are different kinds of horses. The Kubota are Clydesdales and the MTD are the plastic horses you get at Toys R US...
I have a Kubota BX 2230 and am amazed at what the 22 hp will do. My biggest limitation often is traction.
   / Help Understanding Tractor HP and Prices #7
Hi Adam,
That is a good question that I'm sure is shared by many looking at riding mowers and tractors. We could go into detail, as some have already mentioned, about torque throughout a broad rpm range, operating life at rated output, robustness of trannies, robustness of chassis, ease of operating (power steering). However you will get the quickest and most complete answer by driving a $1500 rider mower and than a $15k tractor. There is absolutely nothing comparable beyond they both have 4 wheels and a can mow the lawn.
The $1500 rider can last for several years and perhaps even a few hundred hours if it is only used to cut grass on flat, smooth turf. Have to go up and down a steep slope? The grapefruit sized tranny on the rider will be cooked after the second year. It will leak by internally and not go up the hill when it gets hot. Same thing will happen if you want to pull a cart loaded with soil. The machine is challenged to handle anything more than a operator and a grass catcher in terms of weight.
The decision comes down to if you want a rider to use just for mowing a smooth, flat fairly small lawn and nothing else, the $1500 rider could very well last quite a while, 5, 7 or more years. Anything more demanding and the machine will either simply not do it or will fail in short order.
So you have to match a machine to your tasks, conditions, life span expectations, comfort expectations and budget (short term and long term).
I have nothing against the $1500 big box store ride on's. They have their place and can provide a very good solution to the right situation. The buyer needs to make sure their personal situation matches that machine.
After all that, stop by your local tractor dealer and take a test drive. I'm sure the difference will be clear. Only you can decide if the difference is "worth it".
Oh, and the Hp ratings on ride on mowers are largely irrelevant. 15 years ago I bought a 2 cyl ride on rated at 16 hp. Now comparable machines are rated over 20hp. 30 years ago the comparable (much better built actually) machines were rated at 12hp. Meaningless advertising. Any ride on will have enough power to mow with the deck it comes with.
   / Help Understanding Tractor HP and Prices #8
Torque, torque, torque. Compare the engine torque numbers and you'll see what the difference is.
   / Help Understanding Tractor HP and Prices #9
In most modern terms yes.
Gas tractor engines though, can match diesel tractor power and torque curves. However... Gas tractor engines tend to be bigger, and use more fuel. My old Farmall made a little more hp and torque than my old Kubota(20hp vs 19hp). But, the Farmall was almost twice the cubic inches.
In most cases, a lawn tractor makes peak hp like an old 2-stroke dirtbike; in a very narrow rpm band. Fine for mowing a lawn, but not much use for anything else.
   / Help Understanding Tractor HP and Prices #10
Cute comparison, LOL.
To the OP: good question.
Take a riding mower and cut 5-10 acres and I don't think it will last very long. Do the same with a compact utility tractor, and it will be going strong 20 years later. Plus, if you need to do other work, hauling firewood, tilling a garden, etc., there is no comparison.
Ken
2021 New Holland C327 Compact Track Loader (A51039)
2021 New Holland...
John Deere 350 PTO Manure Spreader (A51039)
John Deere 350 PTO...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
