Help! will a 2034 snowplow fit on a b7200 HST 4wd?
   / Help! will a 2034 snowplow fit on a b7200 HST 4wd? #1
Elkhunter3
Owego, ny
Kubota b7200
Anyone know if a 2034 snow plow will fit on a B7200? I can not find any info on the 2034 plow! I believe it came off a B1750. Thanks
   / Help! will a 2034 snowplow fit on a b7200 HST 4wd? #2
Is the plow for a QA FEL or does it require a sub frame? If you need a sub frame they cost right around 1000usd.
The plow has the sub frame with it,
   / Help! will a 2034 snowplow fit on a b7200 HST 4wd? #4
Not sure if your dealer has a cross reference but I'm guessing that the subframe is different from model to model.
   / Help! will a 2034 snowplow fit on a b7200 HST 4wd? #5
Can you post a picture of the plow dataplate? I dont get any results for a model "2034" attatchemnt, I do get some for the B2034.
Per Kubota Tractor Corporation - Parts List (search for B2034 and click on the "local options" link) B2034 is a plow mount subframe which fits the following tractors: B1750D, B1750E, B1750HST-D, B1750HST-E, B5200D, B5200E, B6200D, B6200E, B6200HSTD, B6200HSTE, B7100HST-D NEW TYPE >=S / N60164, B7200D, B7200E, B7200HSTD and B7200HSTE (the D on the end of a model indicates the 4wd variant and the E indicates the 2wd variant).
If that is correct, it should fit your B7200 HST 4WD.
Aaron Z
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
(2) UNUSED 3500# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 3500#...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
