Help with 3pt hitch operation Ford 2310
   / Help with 3pt hitch operation Ford 2310 #1
puddleduck
Hey guys, I am confused with the levers on a Ford 2310 I just bought. The both seem to do the same thing. I know there should be a difference, one should be draft or speed or something. Help me out here............. thanks
   / Help with 3pt hitch operation Ford 2310 #2
If one is a draft control it may function exactly like a position control unless it has an implement attached and under load so it can sense the draft depth. Can you post a picture of the controls in question?
   / Help with 3pt hitch operation Ford 2310 #3
Draft
The lever closest to the seat is draft control. The outer lever is position control. For all operations requiring position control only (most general uses) lower the inside lever all the way to the bottom of the quadrant, and use the position control lever to control the hitch position. For uses requiring draft control raise the draft control lever until you get the desired response, and use the position control to raise and lower the implement. While hitching and unhitching implements, lower the draft lever all the way to prevent unwanted movement of the hitch.
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
Online Buyers Premium (A47384)
Online Buyers...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
