Rotary Cutter Help with Brush Hog?
   / Help with Brush Hog? #1
Mn Snowman
West Central Minnesota
Bobcat Ct235
I Picked up the old 5' Brush Hog pictured below! Does any one know what brand it is? There is no ID plate anywhere on it. I did see a picture of a old Ford hog that looks somewhat the same but the gearbox was not the same.
It works great but the blades could be replaced!
   / Help with Brush Hog? #2
Best to probably pull a blade and measure hole diameter, blade length and any offset then search for matching blade. Had to do that for a 30 yr old off-brand rotary I have. Good luck.
Thanks, Any suggestions on where to buy blades?
   / Help with Brush Hog? #4
Local tractor shop in WA had blades (and stump-jumper plate). I think a lot of mowers used same/similar gearboxes. Other forum members might have sites for reasonably priced blades.
   / Help with Brush Hog? #5
Did you find out the make and model of your machine? I just bought one today and it looks just like this. The seller thinks it is a Ford but I have not found anything online that matches it.
Not sure but all the bolts have a "I/H" on them! International Harvester I think! I asked the dealer but they said it's so old they would not have any info on it!
197390 (A50459)
197390 (A50459)
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
