Help with Howse Rototiller
   / Help with Howse Rototiller #1
Erik Graham
Bronze Member
Toronto, Ontario
Kubota B2630,Ford NAA, Kubota L2550GST
Greetings;
I recently bought a used Howse RTC 48 rototiller. After I got it out of the back of the truck I noticed that I could turn the PTO shaft in one direction (by hand) and have the tines move, but not in the other. If the PTO shaft is turned CCW everything moves freely, it basically will not turn clock wise which is the way my tractor PTO turns. I did hook it up to the tractor and sure enough the moment the PTO is engaged the slip clutch on the tiller starts to slip and the tines do not move. This is a gear drive tiller and all fluids have been changed and refilled. Does anyone have any idea of what to check next? I'm thinking of pulling off the outboard gear box cover and seeing if there is anything obvious but other than that I have no ideas. Any comments or insights appreciated.
Thanks, Erik
   / Help with Howse Rototiller #2
New or Used? Look into the gear box (a29) you may have to take some fluid out to see the gears - turn the PTO and if the problem is not there... take the end cover off (G142) Drain it first. Take photos and let us know what happens....
Adams Conveyor (A51039)
Adams Conveyor...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2018 John Deere S780 Combine (A50657)
2018 John Deere...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2005 International Pier Drilling Truck (A49461)
2005 International...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
