Help with sickle bar.
   / Help with sickle bar. #1
Birch Hill Farm
Bronze Member
Kentucky
International 444
I recently purchased a old MF sickle bar and it is in great shape, but I am having one problem. The wooden bar that connects the flywheel to the blade keeps popping off at the blade. There is a ball and socket type joint that clamps down by flipping a spring loaded lever causing it to clamp onto the ball mounted to blade. The lever keeps flipping causing it to pop off before I can mow more then a few feet. Could the joint just be weak? Can I clamp it down some how or am I doing something else wrong here? Any help appreciated
Thanks Jon.
   / Help with sickle bar. #2
Is this a case for Duct Tape to keep the lever in place?:)
Wooden Bar = Pitman arm
   / Help with sickle bar. #4
Back when we'd have used Binder twine or Baling wire.:D
It worked! It's mowing just fine now, guess I need to order a new part. So how strong is a wooden pitman arm? Why not use something steel.
   / Help with sickle bar. #6
Good show.:)
Wooden Pitman Arms have been in use for a long time. How strong they are I surely do not know.:)
   / Help with sickle bar. #7
Stay with wood....there's a reason it's made of wood.
You want it to snap if it gets under too much stress, in lieu of something else breaking that will cost a lot more to repair.....
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2017 Nissan Titan SV Crew Cab Pickup Truck (A48081)
2017 Nissan Titan...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2013 Ford E-350 Cargo Van (A48081)
2013 Ford E-350...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2015 Ford F-250 Knapheide Service Truck (A48081)
2015 Ford F-250...
