Help... Won't Start (New Info)
   / Help... Won't Start (New Info) #1
wrinkled
XENIA, OH
YANMAR YM-2K
Help... Won\'t Start (New Info)
Hello
I haven't mowed now in a couple of months and I went out to whack down the ole' weeds and I'm having a little trouble. MY YM-2000 looks like it has enough juice but when I turn the key to start I just get a little click and nothing else. The click sounds like it is coming from the small cylindrical device that attaches to the top of the starter motor. (Solenoid ???) I've got the battery on charge now just to make sure but what is the likely problem and how do I resolve it?
Many thanks...
Dave
   / Help... Won't Start (New Info) #2
Re: Help... Won\'t Start
Dave,
If that doesn't work read Bird's post on cleaning terminals under this thread:
<A target="_blank" HREF=http://=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=parts&Number=101883&page=&view=&sb=&o=&vc=1>http://=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=parts&Number=101883&page=&view=&sb=&o=&vc=1</A>
   / Help... Won't Start (New Info) #3
Dave,
Don't know why that didn't work but try this.
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=parts&Number=101883&page=&view=&sb=&o=&vc=1>Won't Start</A>
Re: Help... Won\'t Start (New Info)
Hello
All contacts are clean and the battery is nearly at full charge.
Solenoid still makes a loud clunk and the starter motor doesn't try to do anything...
Any thoughts...
Dave
   / Help... Won't Start (New Info) #5
Try pulling the starter and see if it will spin out of the bell housing. I had a starter get stuck, had to clean it out before it would work. Another was just shot and had to be rebuilt. Last idea. Make sure it is in neutral. If the clutch is stuck it wouldn't let the engine turn over in gear with the clutch depressed. The 2000s I have had have had several stuck clutches if left outside for a while.
   / Help... Won't Start (New Info) #6
Heres what I do and it works half of the time
I take a hammer and I tap the side of the starter
a couple of times,then try to turn it over.
The problem is the solenoid is not engaging
because of dirt,rust, ect...
Try it ! it has worked for me in the field
Tractor Ernie
   / Help... Won't Start (New Info) #7
May even try tapping it while it is energized. Have the wife or a kid give a few slight to medium raps, while you are trying to start it.
My ym1700 needed this one time.
Soundguy
   / Help... Won't Start (New Info) #8
Hi Dave, you need to remove the starter, lay it on yhe ground or workbench, hook a jumper cable, (+), from battery or charger to the battery terminal on the starter and touch the
(-) cable to the metal case. The starter should run. If it does you need to backtrack to the battery. If not, you need to fix the starter. It's just a 12v electric motor, with some reduction gears. Fixin' is 90% detective work and 10% fixin'.....One other thing, make sure the engine will still turn over and has not frozen up.
Hello
Thanks for all your help...
After trying all your suggestions, the last thing I did was to hook it directly to a good car battery. Nothing is turning so I'm assuming its the starter. I've going to have the starter rebuilt and a new solenoid placed on it.
Thanks again...
Dave
   / Help... Won't Start (New Info) #10
Hi Dave,
One other thing you might want to check before you take the starter somewhere is whether the brushes in the starter are worn to a point that they are no longer making contact on the comutator. My Yannie had the same symtoms as you discribe. I did the tapping with a hammer trick, and it worked for a while. When it stopped working I figured it was time for a new solinoid. After installing that, it still didn't work. After some head scratching I discovered the brushes were worn way down. Apparently the tapping was enough to get them to make contact. After new brushes no more problem. Jim
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
2023 Chevrolet Tahoe SUV (A50324)
2023 Chevrolet...
2017 Ford Expedition 4x4 SUV (A50324)
2017 Ford...
