Help....
   / Help.... #1
Maine275DT
OLD....275 DT
Hi All,
I have an L275DT that has been my rock solid buddy for 30 years, and all of a sudden the rear hydraulic lift quit. The bucket operates fine, fluids are good, but the rear lift is dead ads a doornail. I have my York rake rigged up with a come-a-long to the ROPS, but it is getting old...
Any ideas???
Best,
Davis Carver
PS...Sorry, Kubota....
Edgecomb, Maine
   / Help.... #2
Install a pressure gage in the system, and that will help you with trouble shooting, and allow you to monitor the hyd system at any time the engine is running.
To check the relief pressure for the FEL valve, activate one of the FEL levers and let the cyl max out. Gage will show tractor relief pressure. Now activate the 3pt and tell us what happens. If the gage shows no or little pressure, as the the fluid goes through the 3pt on it's way to the tank, so either the valve in stuck in neutral, or the relief or safety valve is open. The seals on the piston might be bad.
2011 PETERBILT 384 TANDEM AXLE TANKER TRUCK AND TANKER TRAILERS (A54607)
2011 PETERBILT 384...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
