Hesston 1160 swather leaking hyd fluid
   / Hesston 1160 swather leaking hyd fluid #1
RCCB
Central Kansas
Ford 8000, MF 1085, IH T-340
I have a 1160 swather that is leaking around the middle of the neck. It looks like a previous owner welded and caulked around the seam. I bought it last fall and used it on 80 acres and it did an ok job, except for leaking oil. I would like to get the problem fixed. Any ideas will be helpful.
   / Hesston 1160 swather leaking hyd fluid #2
I had an oil leak behind the engine on my Farmall M, It was leaking from the implement pump, went to O' Reilly's and ask them. He said to try pouring in a quart of auto transmission fluid. He said it has stop leak in each container, and ingredients that makes the seals swell. So I did and in about 2 weeks it worked no more leak. Gary
   / Hesston 1160 swather leaking hyd fluid #3
I am having the same problem - Did you get yours fixed - any info will be helpful -thanks
I bought some high quality silicone caulk and caulked it real good. I let it cure for a day or two, before I put oil back in it. It has never leaked from that spot again.
   / Hesston 1160 swather leaking hyd fluid #5
Thanks for the reply RCCB - I will try the silicone .
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
