Hi All
I'm looking at a 10 year old B21 with 230 hours on the clock (ie. likely replaced) which the current 2nd owner says has in actuality, 2800 hours (i.e. I have no reason to doubt). Most of the hours were put on by the first landscape owner in the first 6 years and the tractor appears to be well maintained. Is there a concern with this many hours and what would be a reasonable price for the TLB with and without the extra implements? What can I expect in the way of maintenance down the road especially concerning the engine? Is a rebuild likely in the near future and is there an easy test to determine the engine's condition. Having never worked on diesels, can a compression/leakdown test be performed and what precautions are necessary to do it safely? With regular gasoline engines the spark plugs are removed for both tests and the compression test involves disconnecting the coils to disable the spark. I believe I need to remove the glow plugs and what kind of readings would be good?
All responses welcome
Bill
Bill
