Do the clamps come loose, or the nuts at each end of the line?yes that exactly what i thought .
then i put the rubber it has reduce but not eliminate the problem totally.
the pipe get lose by it self
Aaron Z
The nut at the pump end keeps coming loose and leaking around the nut?it just the nut from the bottom how get loose
I'm wondering if all the clamps are in place as original
The clamps go between all the lines, they help reduce the vibration between them. Either that or there is something damaged with the threads from when the first line came loose
