High Temps & Factory Fluids
   / High Temps & Factory Fluids #1
NoMo
Talala, OK
John Deere 3520
Gets kinda warm (some would say hot) this time of year and I've been wondering about the fluids in my tractor. Only have 32 hours on it so the factory lo-vis is still in the tractor.
Looking at the owner's manual, lo-vis Hy-Gard is recommended for temps up to around 100 F. We may be hitting that this weekend- and for sure in July & August! /forums/images/graemlins/crazy.gif
Should I change to "regular" Hy-Gard for the 3 or 4 months where temps will be near/over 100 degrees? Or will the Low-Vis fluid be OK?
   / High Temps & Factory Fluids #3
As shown in the document, both are fine and have different properties, i.e., one better for start ups in colder conditions vs. the other better in warm. In your case, I would use regular Hyguard.
   / High Temps & Factory Fluids #4
   / High Temps & Factory Fluids #5
I would use regular Hyguard, it's good from 0 to 122 degrees, if your tractor is in a garage you will never have a problem. The low viscosity Hyguard is good from -40 to 85 degrees.
   / High Temps & Factory Fluids #6
   / High Temps & Factory Fluids #7
Here's the temps for both.
   / High Temps & Factory Fluids #8
Thanks for the replies. So it seems I should change out the factory fill for some 'regular' Hygard.
One thing that I find interesting is that the specs for Hy-Gard on the parts pages differs from the tractor's owners manual.
I've attached the vis/temp chart from the owner's manual.
   / High Temps & Factory Fluids #11
Got this from my service manual.
   / High Temps & Factory Fluids #12
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
Freighliner Tender Truck (A56438)
Freighliner Tender...
