Hino e2004 clutch adjustment? and front end leak
   / Hino e2004 clutch adjustment? and front end leak #1
agcomike
southern states
Hinomoto e2004 aka 5020
1) I was wondering on left side where the clutch pedal is what does that yellow decal state? (looks like something about adjusting or something?)
2) Need info on clutch/clutch pedal adjustment
3)i noticed my pto shaft moving everyonce in a while (1/4-1/2 turn at a time maybe normal?) when the pto lever was off maybe related to needing clutch adjustment?
4)also have a transmission leak at the front axe u-joint area where the driveshaft comes into the front axle it's spilling trans fluid when i park on slight incline is the seal on back of trans or in front? also do you have to remove front axle to get shield/driveline off?
thanks
John Deere 2155 Tractor (A51573)
John Deere 2155...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
John Deere HPX615E Gator 4x4 Utility Cart (A51691)
John Deere HPX615E...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
