Hinomoto E2304D, cant engage first or reverse gears
   / Hinomoto E2304D, cant engage first or reverse gears #1
antonyg
mumballup west australia
Hinomoto E2304D
Hello
Could someone with Hinomoto expertise be able to give me a lead as to what the problem might be. Thanks for now.
Regards
TonyG
   / Hinomoto E2304D, cant engage first or reverse gears #2
Does the shifter move freely or feel like it is jammed? Need a little more info. and is first and reverse on the same section of the shift pattern?
hello
thanks for reply, first gear is left top and reverse left bottom, second and third gear are on right side of pattern and engage freely. The gear shift moves accross to left easily but wont engage top (1st) or bottom (reverse) on pattern. Snchro ring may have slipped has been mentioned.
Regards
Tony
   / Hinomoto E2304D, cant engage first or reverse gears #4
Slipped or broken and slipped. I had that issue on my yanmar for the 1st/3rd shift fork. most of the tractors I've dealt with the issue you have to split the tractor to replace.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
2012 JOHN DEERE 310K BACKHOE (A51406)
2012 JOHN DEERE...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
