Hinomoto e232 overheating
   / Hinomoto e232 overheating #1
Hinomotoguy
Hinomoto e232
Tractor fan belt broke. When realized it the tractor was running hot. Observed play in waterpump. Replaced waterpump, hoses, and installed new fan belt. Also replaced the fan with its replacement (original had 5 larger blades vs. six smaller blades on replacement fan) which is shown in the Massey Ferguson 210 (some items between the two tractors are interchangable). Still running hot after about 15 minutes of bushhogging. Any ideas?
   / Hinomoto e232 overheating #2
If you are SURE the new water pump is actually moving water your thermostat (if you have one) may be stuck in the closed or nearly closed position. You could also try running the tractor with the front pointed uphill to eliminate air bubbles trapped in the block. Hose out or blow out your radiator fins from back to front to eliminate dust which can prevent cooling air flow.
   / Hinomoto e232 overheating #3
did you top off the coolant after you replaced everything and ran it for a bit?
roadworthy covers the rest.
i have an allis 5020 that has the same engine.
   / Hinomoto e232 overheating #4
I have not seen them advertised in a while, but a product call radiator genie was available. It had 2 long reach wands in the kit. 1 for water and 1 for air.
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2011 Ram 1500 4x4...
1993 JOHN DEERE 444E WHEEL LOADER (A52705)
1993 JOHN DEERE...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55788)
2009 Peterbilt 384...
CASE 610 Sprayer System 2000 Gallons (A55218)
CASE 610 Sprayer...
