Holding a gear to lock a shaft.
   / Holding a gear to lock a shaft. #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
I need to remove a nut holding a gear on the end of a shaft. the shaft drives a small hydraulic pump. The gear is driven by a gearbox driven by the PTO on my tractor. The gear is about an inch long and 3/4 inch in diameter. The nut is 11/16. I will damage the gear if I grip it with vice grips, about the only way I know to hold it. I am grateful for any suggestions.
Harold
   / Holding a gear to lock a shaft. #3
old piece of leather or rubber to protect the gear?
   / Holding a gear to lock a shaft. #4
Harold
Get yourself a nut splitter and turn the bolt and the nut will split. A Dremel tool will also work. I have cut a 2 in steel collar off of a shaft.
I tried leather inside the vice grip jaws and it still slips. I don't have an impact wrench, but I will look for one later this week if it's not off sooner.
Harold
The nut is very thin. I don't where I would get a replacement for it.
Harold
   / Holding a gear to lock a shaft. #7
I'd try a hard wood wedge(probably oak) between the driving and driven gears. If you don't have access to an impact wrench, use a breaker bar/socket and a 3lb hammer. One sharp rap and you should be able to turn it off
   / Holding a gear to lock a shaft. #8
has anyone thought it might be left hand thread
   / Holding a gear to lock a shaft. #9
No, of course not :eek:
   / Holding a gear to lock a shaft. #10
Can you drill a small hole in it and run a steel rod thru to pin against a housing?
How about a small adjustable spanner wrench to engage the gear teeth. The picture is of an old Armstrong spanner I bought from e-scam-bay for 10 bucks this summer.
jb
2016 Ford Fusion SE AWD Sedan (A50324)
2016 Ford Fusion...
John Deere Z994R (A50121)
John Deere Z994R...
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
