Hole spacing for cutting edge?
   / Hole spacing for cutting edge? #1
The Haymaker
Veteran Member
Benton, Maine
2008 T2220
Is there a standard? What is it?
My NH 68" bucket currently is 9.25"oc, I'm assuming it is actually metric?
The cutting edge will be a future add-on to the snow pushers I am building, so being able to drill the holes now before welding in a spacing widely available would be much easier.
   / Hole spacing for cutting edge? #2
My Case 580K 63hp has an 81" bucket with a replaceable cutting edge having ten bolts spaced 8.0" apart.
I would look around and determine which cutting edge that you want to use. It's probably predrilled.
   / Hole spacing for cutting edge? #3
12" is what I've seen on most blades, with sometimes the outer two located at 6" spacing.
Thanks for the help guys. I ended up going with a 6*12 spacing because it matched a common, cheap, snowplow edge.
Thanks for the link, it explained the hole spacing well for future reference.
E
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
