Homemade pallet forks
   / Homemade pallet forks #1
deanwerden
wyoming, on
2010 Cub Cadet sc2400
I set out to make some forks that were correctly proportioned to my tractor and not take up half of the load capacity. Just a couple pictures for now I have to finish welding everything and my mounting bracket should be done tommorow hopefully. I have right around 100 bucks in material in it
   / Homemade pallet forks #4
when you are done let me know how much you want to sell them for
   / Homemade pallet forks #5
Will those be quick mount? My next tractor will have the fancy skid steer system.
No it won't be quick attach but my bucket is 3 pins with 1/4 bolts holding in the pins. I'm going to replace the bolts with spring pins, can't see it taking any longer than 2 minutes to change
All finished up finally
And here's an old kubota blade I picked up for 100 bucks without realizing it was cat 0. ended up widening 4 inches as well and painted over the orange of course
This splitter is a heavy ***** it will only pick it about 8 inches
   / Homemade pallet forks #8
How did you get such nice welds using that little propane bottle? ;-)
a little thing called patience my friend
   / Homemade pallet forks #10
Very nice forks. Do you have an estimate on how much the whole setup weighs? It looks nice and light for the smaller tractors. Would you mind sharing a few details, such as tubing sizes/wall thickness, etc? Trying to design one for my Kubota without killing the loader capacity. Looking at designs like this helps get an idea what works.
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
Barn Wood Planter Box (A50515)
Barn Wood Planter...
2013 Ford F-150 (A50120)
2013 Ford F-150...
2010 FORD F150 WORK PICKUP TRUCK (A52141)
2010 FORD F150...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
