HOMIER 4 FT ROUGH CUT MOWER-BX2200 ATTACHMENT
   / HOMIER 4 FT ROUGH CUT MOWER-BX2200 ATTACHMENT #1
KRECKER
Bronze Member
MISSISSIPPI
BX2200
Need help in figuring our how to attach this just now purchased 4 ft roughc ut mower to my BX220 three point.
Problem is that when I hook it up to the lower links and top links that it is to so close to the rear tires that there is no room for movement either up or down. The instruction manual is of no help what so ever. Has anyone had this experience when trying to hook up at rough cut mower to your BX2200? Any advise would be appreciated.
Don
   / HOMIER 4 FT ROUGH CUT MOWER-BX2200 ATTACHMENT #2
You might try turning the lower pins on the attachment around so they point inwards.
Ben
Ben,
Thanks for reply, I did reverse the pins to the inside, but this didn't solve the problem. The lower links need to be longer from what I can tell because the mower is so close to the rear tires I can't raise it up or down without hitting the tires.
The mower weights less than my 5 ft box blade so, lifting capacity is not the problem.
Has any one had to lenghten your lower arms to accommediate an attachment?
   / HOMIER 4 FT ROUGH CUT MOWER-BX2200 ATTACHMENT #4
Sounds like you will be in the market for Pat's Easy Change or maybe a Speeco quick hitch. Either will probably gain you 3-4 critical inches.
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
