Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Trying to cut off the existing hose ends and attach new ones that have a 37* angle for use with a torque tube bulkhead. Don't know what to use to get a clean cut on the braided Gates 3/8" hose. Use Sawzall on first hose, and can't get the 2 part field fitting to screw onto the hose, probably because the hose is not perfectly round. I've tried using an abrasive wheel on an air driven tool to campher the leading edge, so the outer part of the fitting can thread onto the hose; no luck so far.
My questions are: what to use to cut the remaining hose, and what to do/use to get the new two part compression like two part fittings to screw onto the existing hoses?
TIA,
CM
TIA,
CM
