How and when to sharpen Rotary BH blades
   / How and when to sharpen Rotary BH blades #1
hz293
Kalama,WA
Kubota B7510HSD
I have a bush hog that I bought a short time ago. My land is mostly 15 degree or better slopes and the terrain is quite uneven. To be safe, I mow up and down the slopes. Actually because of some of the terrain I can't always tell if it's up or sideway because it's deceptive I find that a lot of time I'm englfed in dust. Even if I raise it, if I want to cut weeds and tall grass the brush hog will bottom out and hit dirt. There's a few small rocks but not a bunch.
My question is, how do you know when it's time to sharpen the blades and how do you do it. I looked at the blades when I got it and it just looked like flat stock. what am I missing?
Harris
   / How and when to sharpen Rotary BH blades #2
If you use the search function, you should find lots of previous discussions on the topic of sharpening brush hog or rotary cutter blades. Most manuals say to leave approximately a 1/8" flat edge on them instead of making them sharp as you would with a lawn mower or finish mower. That's because they are made to cut (or shatter) woody type material (brush, bushes, or saplings) and a razor edge would very quickly have nicks in it. Of course if all you're cutting with yours is grass, you can certainly sharpen it to a finer edge to get a neater, cleaner cut.
As for how to sharpen it? Some sharpen the blades with an angle grinder without removing the blades from the machine. Others remove the blades and sharpen them on a bench grinder or put them in a vise and sharpen them with an angle grinder. I've tried all three of those methods and don't know that I have a preference, but of course, I had an air impact wrench to remove blades. If you don't have big enough or strong enough wrenches to remove the blades, then the angle grinder is the way to go.
   / How and when to sharpen Rotary BH blades #3
Hoist that puppy way up in the air and get your angle grinder out and grind away. It's the simplest and fastest way.
If you try and take the blades off, you'll get frustrated VERY quickly....
   / How and when to sharpen Rotary BH blades #4
Harris
When? When they need it. Actually, it's best to touch them up periodically BEFORE they really HAVE to be ground. It's easier that way and you don't have to suffer through poor results mowing until the baldes are too far gone.
I usually sharpen 3 or 4 times a summer. That translates to around 15 to 20 hours of mowing between touch-ups.
How? In 35+ years, I've removed ONE set of blades to grind. It's unneccisary and time consuming. I raise the mower as far as the 3-point will lift it, then back the tail wheel up onto my trailerto support it. I block the front end with jack stands or wood blocks. Even then, I don't actually get UNDER the mower. I don't want to be a statistic.
4" angle grinder and a face shield. Don't grind the edge at too abrupt of an angle nor too flat. 55% seems to work well for me, although I usually just "eyeball" the angle. Any nicks or rolled edge that sticks below the cutting edge, I grind off flat before working the cutting angle. Then I grind just enough to clean up the edge. They don't need to be like a surgical scalpel. Slightly blunt edge does a sufficient job. Too sharp cuts brush rather than shattering it. That leaves tire killers. Too sharp also doesn't hold an edge for long in dirt,rocks, brush and all the other assorted gremlins a bush hog gets into. I try for 1/16th" at the absolute sharpest, and prefer around 1/8th" blunt edge.
   / How and when to sharpen Rotary BH blades #5
I may be alone on this one, but I have never sharpened bush hog type mower blades. I figure they are for a rough cut and I usually hit rocks, limbs and so on. My 6' mower is probably 20 years old. Heck, I never look under the thing unless something wrapped around the blades. Maybe that is where Jimmy Hoffa is? I bought is used 10 years ago for $250 but have changed the gear box oil and grease it regularly. Just mowed down probably 100 cedar trees, some 5'-6' tall two weeks ago but went very slow over the big ones.
Finish mower blades are a totally different story. 3-4 times per year.
   / How and when to sharpen Rotary BH blades #6
Factory recommends my blades get sharpened to 1/16" at the edge (Rhino SE6) I check them every few hours and only felt I had to sharpen once (after maybe 20 hrs of cutting). I raise the rig up, put concrete blocks under the edges so I don't get surprised and use a 4" angle grinder, takes about 20 sec of touch up per blade and it's done.
Total time from when I shut off the tractor to when I turn it back on again is around 5 min or so.
   / How and when to sharpen Rotary BH blades #7
radman1 said:
I may be alone on this one, but I have never sharpened bush hog type mower blades. I figure they are for a rough cut and I usually hit rocks, limbs and so on. 3-4 times per year.
Agreed! A brush hog used as intended doesn't benefit much from sharpening at all. Heavy brush, rocks, and dirt piles will only undo a sharp edge in 30 minutes.
Problem is, when you hog your rough stuff and remove your rocks, you end up with a nice grass field. Instead of buying a finishing mower, I kept using my brush hog, trying to make it mow like a finishing mower. In my case, it helps a lot to keep the blades sharp. It's like daylight and dark. Sharp blades do a 200% better job, and require a lot less power. I keep my blades dead sharp, and do a 15 minute touchup before each use. Reducing the PTO RPM just a bit keeps the blades sharp 2x longer.
   / How and when to sharpen Rotary BH blades #8
I have a similar situation with my 6 ft. bush hog blades. Over the past two years I've noticed that they just are not cutting as cleanly as I would like. I would like to sharpen the blades in place and wondered how difficult it would be with an angle grinder. Since my tractor is a Mahindra 3510, I want to get all the cutting action I can without sapping the horsepower.
   / How and when to sharpen Rotary BH blades #9
It is not difficult at all. Just raise it up, support it, and go to work on the blades. They don't need to be real sharp. Don't even crawl under there, just reach in with the grinder.
If you have the stuff to remove the blades, do so, and sharpen. Impact wrench, 1 1/2 socket, or whatever. There is a hole in the top plate with a cover. just for this.
   / How and when to sharpen Rotary BH blades #10
Got a 5 ft kk cutter that has 7-8 years on it just cutting grass and weeds,very little brush,no rocks,etc. Still does a fine job cutting, never sharpened blades.
Figured,[if mower still is workin when they do need some attention] would just take torch,cut bolts off,and put new blades on,seems the simplist thing to me to do.
Always sharpen my own lawn mower blades[got an old sears mower that I have shapened probably 10 times,same blades] so not worried about doing it,just figured to sharpen them right,would need to take them off hog,and if I was going to go through that probably painfull procedure,would just cut bolts off and put new blades on,than I'd be good for another 10 year??!!
excavator trenching bucket- one bucket per lot (A56438)
excavator...
SCREENER (A58214)
SCREENER (A58214)
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2018 CATERPILLAR...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
