Traction How can I get front wheel traction?
   / How can I get front wheel traction? #1
Tractorganic
Lower CT River Valley/US/Blue Moon Farm
NH/TC40D SS; BCS 850, Brush Mower, Sulky, 'Tiller, Chipper, Snow Blower; JD X570-48-A
I'm trying to plow snow with my FEL and bucket on my TC40D Super Steer (chains on rear wheels) and I'm getting thrown off course with each pass.
How can I get the front wheels to track where I want. Extra snow in the bucket doesn't seem to help. Neither does bucket angle. Raising the FEL helps a little sometimes, but doesn't allow a clean pass.
Thanks,
Chris
   / How can I get front wheel traction? #2
Put a set of V-bar chains on the front wheels. That solved the problem for me when pushing deep snow with front blade on ice.
   / How can I get front wheel traction? #3
I put a regular set of chains on mine and it helped, wish I had some V bars for it. Ed
   / How can I get front wheel traction? #4
2 link v bars chains and a little weight on the front end as in dont put down pressure on the loader.. You can also split the rear brakes and steer that way.
   / How can I get front wheel traction? #5
I just put some truck tire chains on the front of my TC29D and it made a big difference in steering ability. There's lots of these laying around for cheap or free if you look in the right place.
I tried separating and steering with the rear brakes. Works OK when I get the hang of it but, still sliding.
I started a new post re/ front chains +/or filling front tires w/ Rim Guard because I think TBN frowns on changing topics mid stream or hijacking others' posts 'cuz it's harder to look up topics.
Thanks,
Chris
   / How can I get front wheel traction? #7
Weight = traction.
Putting the FEL down subtracts weight (and adds a resistance in trying to turn). Even in float, the geometry of the FEL & pushing against a forward resistance may raise (or lighten) the weight on front wheels (no matter if you have chains or loaded tires).
(IMHO): 1) Use split brakes. 2) Slightly raise FEL (just enough) for tires to grab (yes, chains would help them grab, but the main factor/problem is weight).
2018 TRAILSTAR END DUMP TRAILER (A50854)
2018 TRAILSTAR END...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
