How can I use my stabilizer bars with a QH
   / How can I use my stabilizer bars with a QH #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
I finally got to use my Harbor Freight quick hitch today.
I had to remove my stabilizer bars.
How can I use my stabilizer bars with my QH.
Thanks.
Early 1949 8N
Pooh Bear
   / How can I use my stabilizer bars with a QH #2
A pic of your situation might help. Some modification of the stabilizers may be needed, but am not sure which bars you are questioning.
   / How can I use my stabilizer bars with a QH #4
What are you trying to accomplish with those stabilizer bars?
   / How can I use my stabilizer bars with a QH #5
Yours hooks on to the lift arm pin, correct? If so Just replace the short lift arm pins that cam with the QH with longer ones and you will still be able to attach the sway bar. Depending on which way the bars hook, either on the outside or the inside of the lift arm, just install the pin from the opposite direction so it doesn't have to be removed each time you want to install or remove the sway bar.
I was hoping that would be all it would take.
When some of the heavier implements flop side
to side it feels like I'm gonna break something.
Thanks.
Pooh Bear
2000 Dnya RGN T/A Trailer (A49461)
2000 Dnya RGN T/A...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2021 Exmark Lazer Z 60in Zero Turn Mower (A49461)
2021 Exmark Lazer...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
