How did I do w/o the FEL before ?!?!?
   / How did I do w/o the FEL before ?!?!? #1
Volfandt
Veteran Member
TN
2004 Kubota BX23, 1966 WheelHorse 856
Seems I find uses for it all the time.
Last nght decided to dismount the FEL, basically just for GP. I dropped it on a dolly and a couple of those little super dollies and just rolled it away over into a corner.
Well, it didn't take very long today when I found out I needed the FEL for a couple chores once again.
Funny, it only took less than a couple minutes to remount it, where as it probably took 15 minutes or so to dismount it the 1st time.
I'm thinkng that with the ease the FEL comes off & back on as well as it's all around usefulness in all sorts of duties that 'll probably just leave it mounted up until I mow.
Besdes, I don't know where the ole wheelbarrow's at anywho /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / How did I do w/o the FEL before ?!?!? #2
<font color="blue"> Seems I find uses for it all the time.
</font>
I'm wondering what you've been using the FEL and backhoe to dig in? From where I sit I can still see a nice coat of paint on both buckets. Are you painting them after you get finished using them for your many projects? /forums/images/graemlins/wink.gif
I touch mine up from time to time with a paint brush and black satin paint, makes them both look like brand new. Junkman turned me on to the satin black paint, seems it works on Kubota's and New Holland's as well. /forums/images/graemlins/grin.gif
It do have a little shine gong on in the FEL don't it /forums/images/graemlins/grin.gif
Must be that tough Kubota orange paint /forums/images/graemlins/wink.gif
As for that black satin paint, I'll just go on ahead and leave that for Junk /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Volfandt
   / How did I do w/o the FEL before ?!?!? #4
I feel the same way. I went to an auction this morning and unloaded the truck with the FEL. It used to be a job requiring a whole lo of effort. Slide something heavy out of the pickup bed, manhandle it across the driveway with a hand truck, walk it over the 1.5" lip at the ege of the garage, slide it around into position, etc. Now I just drop the bucket on the tailgate, balance the heavy item in the bucket and roll the bucket back, strap it in if necessary, lift the bucket, press the go pedal, and take a sip from my beverage. Not to mention it's also handy for lifting stuff to the roof of the house when necessary, and it was after the huricanes in Oct 04. No more carrying 5 gallon pails of tar up a ladder.
   / How did I do w/o the FEL before ?!?!? #5
</font><font color="blue" class="small">( No more carrying 5 gallon pails of tar up a ladder.)</font>
Do you need to use the diff lock to get the tractor to climb the ladder? /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
   / How did I do w/o the FEL before ?!?!? #6
Nah, you just need a good running start. /forums/images/graemlins/smile.gif
Actually, I made a little table to hang over the bucket that would put the table top just over the edge of the roof when the loader is all the way up. Loaded tar buckets, tools, and lots of shingles on the roof that way.
   / How did I do w/o the FEL before ?!?!? #7
</font><font color="blue" class="small">( Nah, you just need a good running start. /forums/images/graemlins/smile.gif )</font>
You guys are too funny.
My wife suggested that perhaps you would have one man stand on the bottom rung of the ladder holding the tar bucket, then lift the ladder with the FEL that way if the FEL doesn't reach quite high enough you can still climb the rest of the way.
I think I've forwarded too many of those Oops pictures to her.
Cliff
   / How did I do w/o the FEL before ?!?!? #8
I have found that the FEL is even useful when moving
a couch with a hideaway bed (very heavy). See attached photo. No comments about the ROPS please, I had to lower it to fit through the garage door where the couch was being stored during remodeling of the family room.
   / How did I do w/o the FEL before ?!?!? #9
and let's not forget 36 inch diameter logs
(see another attached photo)
   / How did I do w/o the FEL before ?!?!? #10
Now that's a big log. What did you cut it with?
NEW 2017 Xtreme Green Utility Vehicle 72V w/Locking Tool Drawers, Tow Hitch, LED Work Station (A46877)
NEW 2017 Xtreme...
Fleco 65mm Main Pin Hydraulic Thumb (A42203)
Fleco 65mm Main...
New/Unused Hydraulic Pallet Forks (A44391)
New/Unused...
2012 WABASH DURAPLATE DRY VAN TRAILER (A43004)
2012 WABASH...
2018 INTERNATIONAL RH613 DAY CAB (A45046)
2018 INTERNATIONAL...
Wacker RT Walk behind Trench Compactor (A44391)
Wacker RT Walk...
