How do I combat chiggers?
   / How do I combat chiggers? #1
Workstead
Jonesboro, AR
MF 1010, MF 1250 with MF1246 Loader
I didn't know where to post this but since the chiggers are attaching themselves to me I guess ATTACHMENTS is as good a place as any.
I am fairly sensitive to chiggers. If I get a few around my ankles and don't get them all off I end up scratching them at night and then they get infected. The itch is really strong and I would like to prevent them from attaching themselves to me.
So my question is - how can I reduce, or eliminate, the darn chiggers from getting on me when I am working in the grass or pasture.
Then, if they do get on me how can I get rid of them.
Then if some still get under my skin - pun intended - how can I eliminate or reduce that real strong itch?
I am trying to stay off the grass or pasture but I need to do some work in the field pretty soon and I'd like to be able to sleep at night.
Thanks for any help you can give me.
Clem
   / How do I combat chiggers? #2
A trick some one taught me in Missouri, (full of chiggers) was to use a good anti perspirant. It will suck the moisture out of them before they can do there thing. I put the speed stick style around my ankles and belt area. Worked great for me.
   / How do I combat chiggers? #3
theres only 1 way i know to keep chiggers off of you,an thats not get out where you think they are.but if you have boots that gets oil an grease on their soles every day you might be safe.i havent had probs with chiggers in years,an i go in some tall grass an weeds.i guess they dont like my blood anymore.
   / How do I combat chiggers? #4
I like that you posted in "Attachments"! :laughing:
Oh, man, this subject is close to home for me. I've gotten chiggers prob 15 times over the past year.
So my question is - how can I reduce, or eliminate, - the darn chiggers from getting on me when I am working in the grass or pasture.
I'll start off with "good luck", 'cause you're gonna need it. Then ... Try spraying your feet, ankles, socks, shoes & pant legs with regular ol' bug spray. That seems to keep (most of) them from bothering to climb up past it to get to where you haven't sprayed.
Another suggestion I read & tried but don't really believe to have worked is sulfur powder. Suggested to mix a small amount in with baby powder & then sprinkle it all down your pants, socks & shoes. You will smell pretty darn bad, but I'm not convinced the chiggers care.
I've also heard to keep your pant legs tucked into your socks. Not only will you look ridiculous, but it also didn't seem to help :eek:
You can't. It's too late by then. They say if you jump in the shower immediately you can shower them off before they bite you ... but who gets chiggers out in the woods or a field & is then right next to a shower? :confused2:
And you really never know you got them until the itching begins, & then it's way too late. You're in for itchy scratchy fun for the next 4 - 7 days, in my experience.
No way to eliminate it. Best you can do is calamine lotion, which creates a sort of crust that seems to sort of scratch for you. I dunno, I'm not sure what it does exactly, but it does help a little. Rubbing alcohol also helps a little - Cools your skin & diverts your attention, for a little while anyway.
I hear ya. I'd love to have an absolute preventative for you and me ... but there doesn't seem to be any guarantee.
   / How do I combat chiggers? #5
An old trick here in the south is to add a cup of bleach to your bath water and take a bath. That being said, I am a shower person ( I know, way too much info.) After your "bath" and you pull the tub plug then take a normal shower to get the bleach off. This is not prevention, just a way to get rid of them.
   / How do I combat chiggers? #7
When I was a youngster we would sprinkle sulphur in our socks when we had socks. Seemed to work. Probably the sulphur is worse for you than the chiggers, but the chiggers bother you right now. I very seldom go fishing unless in a boat, still get chiggers but they target different areas of my body since I've gotten old. Must have something to do with the blood circulation.
   / How do I combat chiggers? #8
chiggars tend to "attach" themselves around wastebands and other places where clothing presses against the skin.
We always used sulfur powder around these areas, it is available from local pharmicies.
There a lots of remedies for already "attached" chiggars, personally I "dig em out" but there are topical solutions available to stop them from itching.
   / How do I combat chiggers? #9
We use the repellant that you spray on your clothes (not your skin) from Bass Pro. Night before spray your socks, pants, shoes, and shirt to let dry. Works for us and the spray lasts for a couple of weeks or so many washings.
If we don't spray, we can't get from the back door to the truck without accumulating attachments.
   / How do I combat chiggers? #10
I use skin-so-soft, Just rub it on around your caves an ankles before putting on your socks.Also if you get them on you a small amount of bleach in a cup of water an a damp wash cloth on the area where they are will kill them. then shower using alot of soap an water.Also if you forget any spray for misquotes will work just spray it right on your socks an belt area or neck line.
Army Grunt
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
2013 CATERPILLAR D5K2XL CRAWLER DOZER (A52705)
2013 CATERPILLAR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Galvanized Livestock Wire Gates (4X Gates) (A55218)
Galvanized...
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
