How do you check a wet clutch to see if it is good?
   / How do you check a wet clutch to see if it is good? #1
Mseriesfreak
I have a high hour JD6410 and as you know the clutch is in oil.I know how to check a dry clutch by putting the tractor in high gear reving up engine and holding the brakes and let out on pedal if it kills engine it is good.Can you do the same w/wet clutch?
   / How do you check a wet clutch to see if it is good? #2
My father owned an Allis Chalmers WD-45 which had a wet clutch. He did rebuild the sleeved motor a few times but never the clutch.
I would say in a tractor if you don't abuse it the clutch will last for years.
Just my 2 cents.
Don
   / How do you check a wet clutch to see if it is good? #3
On motorcycles --can't say about tractors-- a bad clutch will slip in similar circumstances, i.e., high load. Procedure to verify is to mike all friction discs, metal discs, and springs & compare with specs-it doesn't take much thickness reduction to make a big difference.... but those are generally pretty accessible on a bike by removing a side cover, after draining oil. What are you going to have to go through to pull it on a JD?
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
CFG Industrial QK20R (A53316)
CFG Industrial...
2009 Ford E-350 Cargo Van (A55788)
2009 Ford E-350...
2016 Ford F-550 Shuttle Bus (A55788)
2016 Ford F-550...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
