How do you flare 0.095" wa?ll, steel hydraulic tubing
   / How do you flare 0.095" wa?ll, steel hydraulic tubing #1
CumminsFan
SoCal
Cat
I have two 3/4", 0.095" wall steel hydraulic tubes that I need to put a 37 degree SAE flare on.
Local hydraulic supply uses a hand held Rigid 377 flare tool for tubes up to 0.065". The 377 is rated for 0.035" wall tube. The local hydraulic supply has no capability to flare 0.095" tube. I haven't yet located a supplier that has a hydraulic flaring tool.
Anyone have tips or lessons learned on how to flare a 0.095" hydraulic tube successfully? Can it be done with a hand held tool such as the 377?
Appreciate any and all help.
Regards
   / How do you flare 0.095" wa?ll, steel hydraulic tubing #2
Regards
Ridgid 41285 Tool, Flare 375
Might do the job.
You could always heat the tubing end and "forge" the flare.
   / How do you flare 0.095" wa?ll, steel hydraulic tubing #6
Maybe I missed it. What is the diameter of the line?
I too was thinking a flareless fitting. Like a swageloc
   / How do you flare 0.095" wa?ll, steel hydraulic tubing #7
Both swageloc and ermeto are great fittings and they make them for hydraulic service. Just make sure you get the right pressure rating ones. That is the way I would go in place of any flare type fitting. All flare fittings are vulnerable to vibration causing the flare to break off. When I was working industrial refrigeration and other machinery work we never use flare fittings and replaced a lot of them with flareless types.
Ron
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2020 KUBOTA RTV...
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
